Clutch Diode
    Clutch Diode
    Does anybody know what the stupid clutch diode does? I've been looking at the wiring diagram and can't really figure out what it's used for. Can it be bypassed - or will i end up frying something else?
    It's scary how slow I am!
    '88 HawkGT - crashed as all hell - Hiperform subframe, VFR rear wheel, F3 front end, Penske shock.
    '05 Ducati S2R - Monstrack mirrors, CRG levers, Evoluzione clutch slave cylinder, ProItalia tail chop, Arrow damper, Nichols flywheel, Suburban Machinery bars
    Careful. You're gonna need the clutch...
      Clutches are for sissies, just like brakes!
      I know I dreamed you,
      A sin and a lie.
      I have my freedom,
      But I don't have much time.
      Faith has been broken,
      Tears must be cried.
      Let's do some living,
      After we die.
        Brakes are for stoppies.
        Clutches are for WHEELIES!
          poo! I just ordered a new clutch diode... same part number for a GL1100
            Poo? So you don't like your clutch? That must mean you don't like wheelies, and if you don't like wheelies then you don't believe in our rights to ride a motorcycle, and if you don't believe in our rights to ride a motorcycle then...well Im not sure where Im going with this now that I actually think about it.
            A sin and a lie.
            I have my freedom,
            After we die.
              I said clutch DIODE!!! it's electrical, not mechanical!
                But- But!! The clutch diode...and the...cause it...and it....and the thing....works....cause...
                *runs away crying*
                A sin and a lie.
                I have my freedom,
                After we die.
                  *runs away crying*
                  ROTFLMAO!
                    ok.... now that I'm not wheezing anymore...
                    clutch question...
                    you got that evoluzion... ? slave cylinder...
                    how do you convert to a hydraulic clutch?
                    88 Blue XS-Hawk.... broken and in recovery
                      Re: ok.... now that I'm not wheezing anymore...
                      Originally Posted by XS-Hawk
                      clutch question...
                      The hydraulic clutch is actually for my Ducati, but you can probably convert to a Magura hydraulic clutch... the lever will fit 7/8" bars and the slave cylinder would mount with a custom bracket where the old cable attaches to the motor. I don't think it'll be too difficult - just costly.
                        Not sure if you can bypass it or not, but it's how the bike differentiates between neutral and "clutch"...if I recall propperly. Without it your nuetral light will come on everytime you pull the clutch lever.
                        Want a 5.5" rear wheel? Click Here
                          I don't think the neutral light has anything to do with the clutch lever. The neutral sensor is in the engine case, I believe. The clutch switch probably has more to do with being able to start the bike with the clutch in.
                            hmmm...well I really can't say for certain because I've never really paid attention to it and I've always hacked my harnesses up for race-bikes. A google-search a while back mentioned it a lot in conjunction with the neutral light...so it's heard to say.
                              Can the clutch diode have anything to do with my main fuse blowing as soon as everything is connected on the bike?
