So I’m considering getting an F2 front wheel for the stock front forks and was wondering if anyone has had them work with the Lenac brake bracket?
F2 front wheel on stock forks with Lenac Tokico brakes?
Originally Posted by scientist_on_motorcycle View PostSo I’m considering getting an F2 front wheel for the stock front forks and was wondering if anyone has had them work with the Lenac brake bracket?
Works fucking break.Don't spend money and buy, spend time and learn.
Yes. Pictured below with an EBC ProLite disc. Works great! I also found an F2 speedo drive on ebay, which is more accurate than the stock Hawk IMHO. You need an F2 wheel spacer. Removing the front wheel is tricky because there is not much clearance. Upside is better braking without the extra unsprung weight of twin discs.
