I've noticed some sort of knocking when holding in my clutch coming down from 50mph and up but not at idle or slow speeds any ideas
Mechanical concern
Maybe coming from the chain?
How is your chain slack?
Also; do you normally coast from such high speed with the clutch in?
guessing the chain rubber on the frame is wornGino
Chain Roller
2012 CCS LRRS ULSB Champion
2012 CCS LRRS P89 Champion
ECK RACING
Originally Posted by Dillankb View Post
Should I not coast like that I'm guessing no
For all I know I have your same problem
Could be Shain slop wacking the swing arm. That would be my guess..Don't spend money and buy, spend time and learn.
With the external test it looks fine but I'm probably gonna pull it apart just in case
https://www.hawkgtforum.com/forum/mu...925#post828925
Just adjusted it a month ago on the tighter side
https://www.hawkgtforum.com/forum/mu...632#post824632
Originally Posted by ParcNHawk View Post
The spec is too tight. If you're adjusting to the manual using the factory tool then adjust it to the loose line.
Originally Posted by nt650hawk View Postguessing the chain rubber on the frame is worn
