So I installed the new front stainless brake line and proceeded to try to bleed up a firm lever. Ahh, no go.
The new fluid made its way to the caliper quickly, had some bubbles as usual, figured I was near a new brake but not so much.
Should I be seeing bubbles IN the master reservoir when pumping..? And if I should does that mean I had a different issue like the master just not pumping or other...?
I did this to myself, the brake worked fin prior to this new line. Great huh...?
Thanks,
