I'm guessing my bike might have between 10K and 35K miles on it but there's little way to know the engine's actual mileage. Unfortunately I did two major things at one time--completely disassembled and cleaned the carbs (maintaining exact pilot screw turns and syncronization settings) and adjusted the valve lash. It pretty much had 0 valve clearance and would take a while to start, sometimes backfiring once before getting going, but it pulled strong and there was an immediacy of twisting the throttle and getting power. For a Hawk it felt fast-ish.
After putting in the feeler gauge and adjusting it to have slight drag for first the front, then the rear cylinders at the factory spec, it starts immediately and revs perfectly with no load. However out on the road it has WAY less power. Going uphill at 65mph isn't quite WOT, but I need a lot more throttle than before. There is no immediacy between twisting the throttle while riding--there's no way on the planet it could pop a wheelie now, and before it was kind of possible. Is my gap too large? It's not impossible, but I don't think it's the carbs. Any suggestions?
