So, just stripped the carbs down on project basket case and have found the following: Are these all stock?
Front
142 mains
35 pilot
24 fuel valve
5 hole emulsion tubes
1TH needle
Shorter diaphragm spring in front?
Rear
135 main
35 idle
24 fuel valve
1TH needle
Longer diaphragm spring in rear?
Stock setting 7mm float height
2.5 turns out
The manual only seems to have info for the 650...
Front
142 mains
35 pilot
24 fuel valve
1TH needle
Rear
135 main
35 idle
24 fuel valve
1TH needle
2.5 turns out
