I’ve just started adapting a couple of Keihin CVK carburettors for my 760 Bros (XRV750 engine). They are from a bank of four, off a Kawasaki ZX7R, I think. The bore size is around 38.6mm which perhaps makes them nominally 39mm?
It would be great to hear from anyone else who has done similar - there’s various technical problems to solve and obviously the jetting eventually.
The main technical problems I’ve noted so far are:
Making a second throttle pulley. I’m going to run two separate cables to a twin pull Domino throttle
Adapting the cold start mechanism to the usual NT650 arrangement.
Finding a suitable metal fuel inlet elbow to press in, replacing the plastic pipes usually connecting the carbs in the standard bank set up.
Tidying up the air intake side. I currently have open carbs with bellmouths with a bit of gauze to stop anything big going down there - I’ll probably try to rig up something similar.
I’ve made a start and have the carbs on a spare motor shell and have been machining the cold start plungers to accept cables.
