Bought a Hawk a while back. As far as I know, motor's stock except a Delkavic shorty slip-on. I thought there might be a problem with one of the cylinders cutting out at high rpm and big throttle openings, but wasn't sure. It happened rarely. Decided to have the airbox replaced with pod filters, jets, etc., the work being done by a highly reputed mechanic. Still has the cut-out problem, maybe worse do to more air and fuel being on demand. I changed the fuel filter and removed the pet-cock screen; didn't solve problem. I was advised to check the fuel pump, but the filter was clean that I changed, and it seems the fuel pumps a sealed unit that would just have to be replaced to check. Thinking maybe a float level problem in a carb; the problem seems more likely to occur going up hill. Thought I'd see if anyone else is experienced with this problem and can suggest possible causes.
Fuel starved?
Originally Posted by bk94si View PostYou need to buy a manual. It is possible to check the fuel pump although I doubt that is it. Could be a lot of things. Spark plugs, float levels, torn diaphragms, valve adjustment.
Originally Posted by efishone View PostBought a Hawk a while back. As far as I know, motor's stock except a Delkavic shorty slip-on. I thought there might be a problem with one of the cylinders cutting out at high rpm and big throttle openings, but wasn't sure. It happened rarely. Decided to have the airbox replaced with pod filters, jets, etc., the work being done by a highly reputed mechanic. Still has the cut-out problem, maybe worse do to more air and fuel being on demand. I changed the fuel filter and removed the pet-cock screen; didn't solve problem. I was advised to check the fuel pump, but the filter was clean that I changed, and it seems the fuel pumps a sealed unit that would just have to be replaced to check. Thinking maybe a float level problem in a carb; the problem seems more likely to occur going up hill. Thought I'd see if anyone else is experienced with this problem and can suggest possible causes.9200 rpm? Stock CDI kills ignition at 92-9300 rpm.
maybe replace sparkplugs and do a carb cleaning."It's only getting worse."
