HONDA "F2 vs NT650" Master Cylinder?
  • HONDA "F2 vs NT650" Master Cylinder?
    1991 NT650 SINGLE caliper, master cylinder
    1992 CBRF2 DUAL caliper, master cylinder
    Are they the same part?
    Or is there a "different throw" or "higher compression" for the dual calipers?
    What is the general consensus for using the single disc master of the NT650, to power and push dual discs in the front?
    The issue is I don't have the F2 master cyl. and was hoping to just double banjo the existing hawk master.
    According to my terribly in-accurate Honda parts interchange list, those are the same part. IIRC a 1/2".
    That's pretty small for 4 pistons.
    You want somewhere around 27 to 1 ratio, caliper piston area to master piston area
      A good way to check if they are the same is to see if the rebuild kits are the same.
      The MCs will be different simply because the Hawk GT has a mirror mount and the CBR doesn't. I am pretty sure they are otherwise identical.
        I am no brake guru but I am using a Hawk master with dual F2 disks snd it feels just fine.
          For an increase in the slave fluid volume, you will need an equivalent ratio-metric increase in the master volume. So, to keep the same stroke and lever ratio, you will need a larger bore. If you keep the same bore, the stroke will increase. You can somewhat dial it with the lever ratio using adjustable levers. But basically that's it. If you're fine with your lever travel, you're good. Otherwise, if you want to decrease your lever travel, get a bigger master cylinder. Ideally, match the actual master used for your calipers or the same size master.
          I haven't measured anything but a large single Hawk caliper volume may be close to the smaller dual piston dual caliper volume. You can get close by measuring the area of the pads. If the stroke of the caliper piston is similar, then the area of the pads alone should get you close.
          Sorry if I got a bit wordy and drawn out. But hopefully, you get the idea.
          Eric Y.
          Hawk test chassis
          Yuzon Designworks
            F2 and Hawk have 1/2" master cylinder and use the same rebuild parts.
            Acta non verba
            '88 Blue 99% stock SOLD
            '88 Restomod
            '22 Yamaha Tracer 9 GT
              Originally Posted by eyhonda
              For an increase in the slave fluid volume, you will need an equivalent ratio-metric increase in the master volume. So, to keep the same stroke and lever ratio, you will need a larger bore. If you keep the same bore, the stroke will increase... ...Sorry if I got a bit wordy and drawn out. But hopefully, you get the idea.
              Totally understand, and wordy is good. Perfectly explained thank you.
                Ziggy, thank you for the confirmation. All the input from all you guys, helps me move forward. Thank you!
                  F2 caliper pistons are tiny.
                    25mm vs 30mm on the Hawk. Of course, the F2 uses two calipers.
                    ASMA #139
                      Try a 5/8 (CBR F3, VFR iirc) for a little extra pressure and less travel.
                      88 Hawk GT
                      Talk big. Think small. Do nothing.
                        F3 uses the same 1/2" MC as the F2 and Hawk.
                        ASMA #139
                          Yeah sorry you're right. F3 and VFR gen 4 are 1/2, my Goldwing is 5/8 and CBR600rr (2004) is 11/16.
                          88 Hawk GT
                            Originally Posted by captain 80s
                            f2 caliper pistons are tiny.
                            thay are!!!! Freakishly tiny!
                              I caught a little flack for adding a second F2 caliper/rotor combo to my CB-1 (1/2 F2 master) but when I had two deer run in front of me a few weeks back, I certainly was glad I had them. The feel and modulation is awesome…
