So I found these mini directionals in my Stash-O-Stuff and hooked them to the rear of the '88 GT. The connectors are the perfect size and the wires even match the right hand color codes; blue and green.
Well they blinky-blinky-blinky really fast, I hooked both to see if the fast rate might be caused by an uneven balance with one stock directional still being hooked. I also touched the metal stem to the frame thinking that it might be a ground issue. Both side blink quite rapidly.
Any idea why this is...? The stock directionals blink at a regular rate so I did not think that it is a flasher issue.
Thanks,
Thanks,
