I have fitted new cush drive rubbers cleaned and lubed the cush unit splines and cleaned the swinging arm. Everything fits together no force needed, however when I fit the 46mm nut and torque it up to 120pounds the eccentric chain adjuster can't be moved.
My first thought I must have done up the pinch bolt but nope that's loose. Remove axle nut and cush drive unit and the chain adjuster can be moved easily.
I have read the workshop manual and according to the diagram I haven't missed any parts out. I adjusted chain then did up pinch bolt then torqued up the axle nut and everything seems straight the wheel spins but the adjuster is solid.
Is there supposed to be a spacer between the cush drive unit and the eccentric hub. Worried I might be crushing the wheel bearings.
