Just put some new bits on (Hyperform rear shock). Now after getting everything together I'm noticing play in my rear brake disk. Is this normal? I didn't take the rear wheel off or anything.
Noisy Brakes
Hyperform shock?
I wasn't aware there was one.
I just searched and found Hyperpro shocks... also a surprise.
Play in the rear disc as in the 4 mounting bolts are loose?
Is it possible you didn't notice this before?
I had my rotor bolts loosen on me. You have to take a lot of things off the reach them...
OR you can cut a 6mm allen wrench back really really short to get it in that tight space.
The bitterness of low quality lingers long after the thrill of a low price has gone. - RacerX450 -
You're going to have to remove the rear wheel and hold the nuts!
This gallery has 1 photos.
The bitterness of low quality lingers long after the thrill of a low price has gone. - RacerX450Comment
It is difficult to believe the rear disc is not solidly mounted, standard it is bolted on to the hub against 4 fiber washers and after 30 years these disintegrate so the disc is loose, I have bolted one of mine direct to the hub, no fiber washers, the only reason I can see for the fiber washers is to reduce heat transfer.👍 1Comment
It is difficult to believe the rear disc is not solidly mounted, standard it is bolted on to the hub against 4 fiber washers and after 30 years these disintegrate so the disc is loose, I have bolted one of mine direct to the hub, no fiber washers, the only reason I can see for the fiber washers is to reduce heat transfer.Comment
