I'm in the process of stripping down a hawk and I got a little surprise when I went to drain the coolant. I popped the bolt out of the water pump and about a half cup or so of oil drained out. No coolant. I opened up the pump and there was a little trace oil in it but definitely no water in it or the whole system. I drained the engine oil and there was no milkshake either. The previous owner sent me video of it running (but not well). but who is to say it did or did not have coolant. The guy really had no idea what he was doing so kind of hard to say. I know there has been some damage to the radiator from a fall or something so i can understand if maybe it had a leak and emptied out but I didn't expect oil to come out. Is that perhaps an indicator a seal is gone inside the pump? I would think if so then there would be milkshake in the motor? I can spin the motor over with a ratchet and socket and it has compression with the plugs in. Essetnially nothing feels seized. I didn't really think to do a compression test before I started taking it apart but I'll probably do that later in the week when time permits, but just curious for any suggestions to see what anyone can offer up as an explanation for the oil dump in the coolant pump.
nothing but oil in the coolant pump
90 Hawk GT (color as to yet be determined) - Still on the shelf in cratesTags: None
The oil is definitely old and gassy smelling. That’s A good thought to check the oil filter though I’ll do that this evening88 Blue Hawk GT - Under construction but rideable (guest approved)
I took out the coolant drain bolt initially. It has a little sideways triangle next to it on the pump cover. Regardless of that I pulled the whole pump cover off eventually, radiator and all the bits. Like I said, it’s a tear down to clean and remove some corrosion. There was definitely No coolant in the system, just some oil. Was weird as hell. I’m going to pull a plug in each cylinder and check compression before I take the motor out of the frame and like suggested earlier inspect the oil filter for milkshake. If I don’t find any I’ll probably go ahead and see if I can manage to service the water pump and am probably going to test the waters on one of those eBay aluminum radiators. I think someone posted the parts on rebuilding the pump not too long ago so will dig into that a little. lol88 Blue Hawk GT - Under construction but rideable (guest approved)
Maybe just fill the cooling system with oil and have the first oil cooled Hawkgiphy.gif
- Likes 3
It's a strange one.
Only thing I could think of is if there was never any coolant in there and the oil somehow made it's way past the seal in the pump and was slowly leaking from the crank case into the water pump from the impeller seal.
Having not had a hawk water pump apart that I can remember if they are even a serviceable part, I'm not sure how it seals around the impeller shaft.
Yeah I was thinking along the lines of what 6 was saying, while at the same time thinking that if the bike got hot enough while running without coolant maybe the seal in the water pump failed enough for oil to seep in (no telling wtf else may be destroyed but the motor seems to outwardly be OK. I'll do a compression test on Saturday and probably take a close look at the water pump and see what I can see. I just ran out of time this past weekend to dig deeper and figured I would consult the brain trust!
Thanks fellas!88 Blue Hawk GT - Under construction but rideable (guest approved)
Originally Posted by bk94si View PostI'm wondering if the guy was just trying to make a quick sale. Had no coolant to fill it with and threw some oil in instead just so he could say it was running.ASMA #139
Originally Posted by bk94si View PostI'm wondering if the guy was just trying to make a quick sale. Had no coolant to fill it with and threw some oil in instead just so he could say it was running."It's only getting worse."
