So I took a different ride today than my usual 30 minute romp through the hills near my house which starts out as a 30 minute freeway drone to the other side of the valley.
Three quarters of the way there the bike sputters and dies and I coast to the side of the freeway. It proceeds to do this several more times on my ride so I give up and head home before I find myself completely stuck in the middle of the Santa Cruz mountains with no cell signal. I didn’t feel comfortable staying on the freeway so I took the expressway and stayed in the right lane. This behavior happened one more time on the way home. The very last time it started sputtering near my house I performed an experiment. Instead of pulling off to stop I let off the throttle and pulled the choke all the way. After a few seconds it returned to normal and it was ok after that for the rest of the way. A fellow biker suggested that my float bowls are going empty faster than usual. I’m running unipods with 168/163 jets and a cored out stock canister with dual outlets.
I suspected it may be a tank venting issue again—but I have gone through this before and I have a 49-state cap with a vent on the cap so that is most likely not the problem. The carbs are clean.
My suspicion at this point is that the yellow weed whacker fuel line I run with the vacuum fuel pump is collapsing under the higher heat generated from the longer freeway ride (and higher speeds in those hills!) and choking the carbs.
so my questions is: what spec fuel line do I buy for the lines from the Mikuni to the carbs? Specifically, the inner diameter?
