Hi All,
I am cleaning my carbs, and found one with the slide super stuck. Had to pry it out with something non marring(I removed the C clip on the needle). then noticed that the needle is stuck/corroded into the carb! This seems like a high potential for breakage and ruining half a bank of carbs. This would likely turn this project into a partout. Is there any way to tap the needle from the float side of the carb? Looks like the access is blocked off with a BB press fit into the tube. It is currently bathing in some PB blaster ( after an hour run in the ultrasonic w/heat). Next step i may crank heat up on US with some vinegar, after that possibly boil the carb, maybe try Kroil if PB doesnt work...PITA... Secondly, where can i just get adjustible needles instead of the whole kit?
