Is there a good direct replacement for the fuel pump? OEM is not available and I don't want to go the vacuum route. I hate to take a chance on a used one or a cheap one off ebay. Thanks
replacement fuel pump
^^ yes, all perfectly normal, so carry on.
your previous pump wasn't clicking because it was defective, which is why you replaced it........Last edited by squirrelman; 04-11-2022, 07:37 PM."It's only getting worse."
Originally Posted by jbarneshb View PostI bought and installed a replacement fuel pump from Hordpower. It works fine and does not leak but the pump makes a knocking noise every 15 or 20 seconds. Does anyone know if this is normal? I imagine it running and shutting off but I didn't notice the other making any noise, ThanksDon't spend money and buy, spend time and learn.
