I have an 1989 hawk 650 that I have brought back to life. Love it. Yoshimura slip on muffler, factory pro jet kit. Had the carb’s professionally cleaned and rebuilt. They look perfect. Followed instructions of factory pro jet kit from Hord. Engine would idle, but fell on its face given any throttle. My experience with jet kits is they are always too rich, at least where I live. I am three miles from the Pacific Ocean in far Northern California (Humboldt County). Sea level, cool air and high humidity. After going down, down, down with the jet sizes- 150f 142r small improvement. Replaced ridiculously rich needles with stock ones. Started up and ran great! Lean plugs though. Needles now shimmed 2.0mm, jets at 150 front, 160 rear. Rear still too lean!
new carb boots installed correctly. Vacuum membranes look good. The vacuum slides have a needle holder unlike what is shown in the stock parts schematics found online. The needle holder screws in and then there is a screw on top to hold the needle in. I could move the needle up and down so I took the small spring from the needle holder found online and cut it real short to hold the needle in place. All passages in carbs unrestricted, although I’ll check that again. Replaced port seals in carb spigots. Fuel screws 2.5 out. Where is your favorite place to ride? pilots.
My suspicion is the carbs are no synchronized. Visually the butterflies open exactly together. Can’t find a factory sync vacuum gauge to buy. I have found little on this site referring to synchronization.
Your thoughts?
Thanks in advance,
Bruce Braly
Your thoughts?
Thanks in advance,
Bruce Braly
