I have the ignition key apart. There is no power coming out of the brown wire ( from the key) to power the tail light . ( I do have brake lights)
With the assembly apart I cleaned the contact points and the copper bridge engagement points to insure contact is being made
With that sub assembly put together the contact points can engage (rotated) by hand to see where power is made. Headlight, horn and turn signal all have power
Apparently, the Brown (wired) terminal has no continuity from the top contact point to the solder point at the bottom where the wiring starts to power the tail light .
Likely there is an internal break between the contact point and the solder point.
Anyone have experience with disassembling this and repairing it??
If cannot be repaired, anyone have a spare unit they can part with?
H2
H2
