What kinda batteries do you use? Les Schwabbers or the walmart special? Any brand loyalty? Are all of these smaller bike batteries ones that you cannot maintain?(put water in?)
Favorite Battery??
I used to use yuasa batteries in my hawk, but since I've gotten a new subframe that doesn't really fit a stock sized battery, I had to change to a couple of high discharge rated - sealed batteries (IIRC, it could discharge at a rate of 80 amps).It's scary how slow I am!
'88 HawkGT - crashed as all hell - Hiperform subframe, VFR rear wheel, F3 front end, Penske shock.
'05 Ducati S2R - Monstrack mirrors, CRG levers, Evoluzione clutch slave cylinder, ProItalia tail chop, Arrow damper, Nichols flywheel, Suburban Machinery bars
Has any one used or heard of chrome battery before?? I like the digital display right on top...
Anyway, in the market for a new battery and thought I'd resurface this old thread 10 years later to see if there is new input.
http://www.chromebattery.com/ytx9-bs...s-battery.html
Originally Posted by Enils View PostHas any one used or heard of chrome battery before?? I like the digital display right on top...
My Yuasa (stock size) from 2008 died about a month ago. I was a little disappointed, but it was deep cycled more than a couple of times and been used to power a wrench-to-ring-to-frame arc welder on more than one occasion as well.
I will almost certainly be replacing it with the same.
