I just got a Hawk from my uncle that I have been lusting over for years. It has been in storage for a few years and is gonna need to have the carbs rebuilt. Should I just get a gasket kit from Honda or splurge for a dynojet? The bike has no mods as of now.
Carburetor rebuild
just follow the steps illustrated in the service manual for a simple cleaning, paying attention to idle jets. usually, most "carb kits" aren't needed, just clean things up and reuse parts.
new float bowl gaskets can be made from standard industrial O-rings. -.041.Last edited by squirrelman; 06-30-2022, 05:26 PM."It's only getting worse."
- Likes 4
Originally Posted by squirrelman View Postjust follow the steps illustrated in the service manual for a simple cleaning, paying attention to idle jets. usually, most "carb kits" aren't needed, just clean things up and reuse parts.
post-3647-0-85981000-1347898810.jpgDon't spend money and buy, spend time and learn.
Some people just keep it stock.Gino
Chain Roller
2012 CCS LRRS ULSB Champion
2012 CCS LRRS P89 Champion
ECK RACING
Thanks for the info guys. It's leaking from the left drain screw. I removed it, cleaned it, and it's still leaking plus it's only hitting on one cylinder so I suspect some nasty stuff in the carbs. Gonna go ahead and change the plugs while I'm this far in. Also, any recommendations on air filters? K&N doesn't make one anymore. All I'm finding is Hi-flow brand. I'd like to get one that is cleanable.Last edited by CMilam; 06-30-2022, 05:11 PM.
in addition to the fsm, there is an excellent tutorial on cleaning hawk carbs on this site.
leaking from drain screws is very, very rare, so suspect damaged parts.
Originally Posted by squirrelman View Postin addition to the fsm, there is an excellent tutorial on cleaning hawk carbs on this site.
Originally Posted by CMilam View PostThanks for the info guys. It's leaking from the left drain screw. I removed it, cleaned it, and it's still leaking plus it's only hitting on one cylinder so I suspect some nasty stuff in the carbs. Gonna go ahead and change the plugs while I'm this far in. Also, any recommendations on air filters? K&N doesn't make one anymore. All I'm finding is Hi-flow brand. I'd like to get one that is cleanable.
^^ you might be correct but i believe drain screws on hawks should seal fine without O-rings just by the interlocking of the threads.Last edited by squirrelman; 07-01-2022, 02:20 AM."It's only getting worse."
Originally Posted by CMilam View PostAlso, any recommendations on air filters? K&N doesn't make one anymore. All I'm finding is Hi-flow brand. I'd like to get one that is cleanable.
Originally Posted by squirrelman View Post^^ you might be correct but i believe drain screws on hawks should seal fine without O-rings just by the interlocking of the threads.
Also Squirrel, I have always been curious what makes that happen to the UNi filters and the best I can figure is maybe someone cleaned them with a solvent or maybe oiled them with the wrong oil (or maybe didn't oil them at all). I figure solvent and long sessions of being dry and hot is bad on the foam, but I have no way to confirm or prove that. I just know I have had them for years and no issues on some of my own bikes so not sure if I have just been lucky or whatever. FWIW all I do for cleaning is warm water and dish soap, then very light oiling with the UNI oil. I've definitely seen some destroyed on some project bikes though, especially ones that have been sitting for a long time so it's always made me question what does that to them.88 Blue Hawk GT - Under construction but rideable (guest approved)
Originally Posted by rpcraft View Post(or maybe didn't oil them at all).
I used to clean my Unis with warm and dish soap and re-oil with filter oil. They lasted maybe 6-7 years before starting to disintegrate. I now do not oil or wash them. I just shake the dirt off once in a while. Looking good so far (maybe 4-5 years now). Those numbers are just guesses off the top of my head. I have records at home but I'm not at home right now.Brian - Richland, WA
1997 VFR
The tip of the drain screw into the aluminum carb bowl is absolutely what seals it. The o-ring will prevent some very slight weeping that can occur. It's always best to maintain matched sets of drain screws / float bowls. If installing new screws, you should seat and un-seat them a few times so they find their new "home".
If you've ever removed the screws from nasty float bowls, there is a definitive line where the conical tip sealed against the float bowl and the very tip looks like the rest of the float bowl.Last edited by Captain 80s; 07-01-2022, 01:38 PM."I couldn't afford NOT to buy it!"
