Title says it all except for HELP PLEASE. My 1990 only has about 15k miles on it. When I went through all the maintaince I decided to replace the cables. I didn't pull the clutch cover to check the plates because it had such low miles. Now when I go riding the lever gets slack which is normal I suppose due to the heat. After my ride and after it cools down, my lever does not return to the original free play so I have to adjust it. Now the cable is almost completely out of adjustment at both sides. The clutch doesn't slip at all which is what I thought would be the indicator of a worn out clutch. However it is 22 years old. Do you thing it's just a lousy cable where the outer case is compressing or do I have other clutch issues ?
Clutch needs constant adjustment
