Short story long, for those with a Ducati 916 rear wheel conversion who are using the stock Brembo P2 34 rear caliper, can you do a full rotation of the axle to adjust the chain without the caliper hitting the swingarm?
The longer version is my projects move at a glacial rate, but I'm sticking a 916 rear wheel into my NT400 bike among other plans. I have made a sleeve for the Ducati hub that aligns the chain, and after first thinking I need another spacer I built a little jig to help measure and at the moment I'm happy the rear wheel is central (within tolerance). I've designed and machined a rear caliper hanger based on the 916 standard hanger and am just going through the issue fixing and finalising the design. The test fit with the caliper stops full rotation as it hits the top of the swing arm. I loose about 60 degrees of rotation. I have a couple of options, the first is to check with others who have the conversion if this is 'normal', or if there is something obvious with my design that I've not seen, or if I need to move the caliper mount up a couple of mm to clear the arm.
So obligatory pictures of the design (version 0.1):
And in the rig showing the problem, crude marks on the masking tape shows the rotation problem (hopefully):
Suggestions or ridicule welcomed.
