I'm on a fairly fresh (maybe a 2-3k on it) 700 build. while I was riding the other day, I lost my front cylinder. Determined it's got no spark.
I think my CDI box may have died.. Just looking for some reassurance before I either yank the clutch cover to visually check the pulse coils and trigger wheel (I found an old thread where a guy mentioned his trigger wheel being loose and not spinning?! I don't really think it's this, but the thought scares me...) or drop money on a CDI box.. which I can't do for another week or two.
Coils tested fine as far as ohms, primary and secondary.
Pulse generators as well. Both had nearly identical ohm readings.
I have spark on the rear cylinder.
Checked resistance/continuity on all the wires..
Checked for 12v to the cdi, 12v to the coil.
Checked grounds.
Kill switch is good. N switch is good. Clutch switch is good.
Swapped a known good coil in up front. Still no spark. (works on the rear)
In order to eliminate my bad eyes I even tried a timing light--good on rear, nothing on the front.
This weekend i'm going to try swapping the wires around to the cdi from the pulse coils--I figure that way I can eliminate the pulse generators as the culprit and be sure it's the CDI. I think if I hook the rear pulse coil up to the cdi input for the front coil and vice versa... then have spark up front but not in the back, front pulse coil would be bad. I am incredibly tired and a bit frustrated though so i'm not sure if all that even makes sense..
Anyone?
Checked grounds.
Anyone?
