Alternative Ignition Possibilities
  • Alternative Ignition Possibilities
    So I’m slowly but steadily gaining momentum gathering parts for resurrecting my stricken Hawk. Time to rethink a few things that were problematic with the original build and get it ‘righter’ this time around.
    First up, the OEM ignition switch was wonky, so on the original build I decided to ‘upgrade’ to a Motogadget M-Lock. To be honest, I shoulda kept the wonky ignition switch. The M-Lock could be a royal PITA when it felt like it. And at very inopportune times…
    Seeing as though OEM ignition parts are about as scarce as pristine gauge backs and fully tabbed OEM cowls, I’m looking for alternative approaches to control the ignition. A simple ‘ON/OFF’ switch? That same ON/OFF switch, with a hidden second switch for safety sake? Better RFID options? Quality third party keyed switch manufacturer? Any OEM Honda switches that may be compatible? Because of the CBR600RR front end, I’ve never had a steering lock, so that’s not an issue. The forks have a custom upper triple (thanks wildwhl ) so the OEM switch mounting plan will have to be dealt with separately, but not here.
    Has anyone else been up against the wall with ignition switch issues? Inquiring minds need to know…
    -tom
    (a little concerned over ebay ‘quality’ parts)…
    On my RC26 (that was initially going to be a track only bike) I simply have a quality marine toggle that is not obvious up behind the gauges, but is easily accessed with a gloved finger. This is not a bike that gets parked in strange places for any length of time tho.
    And like you said you could have a truly hidden "master" switch somewhere.
    But I'm an old school analog guy, I want it simple and reliable if I'm not gonna have a keyed ignition. And I have a keyless cap too. I used to have my gas cap key on a stud/wingnut on the upper cowl bracket.
      EMGO has aftermarket ignition switches in the honda style.
        Do you have any experience with them, or know of others? Thanks for your input…
          good reputation, not from china i think.
            Great intel, thx Jerry…
                EMGO and K&L are solid aftermarket choices, lots of experience selling and using them. Or adapt any newer used Honda switch. Also, an early CBR or VFR switch might be really close to the original Hawk unit if so inclined.
                  I've had this unique barrel key K&L switch in my watch list forever.
                  Find many great new & used options and get the best deals for K&L TUBULAR KEY MAIN SWITCH FOR HONDA CBR and VF1000F: P/N 21-3821 at the best online prices at eBay! Free shipping for many products!
                    I am installing the EMGO Generic switches on my CRF after one of the original Baja Designs switches took a hit. Much nicer then the Baja ones anyway. I would use them again.
