Paging DrPMC, wildwhl, and eyhonda for advice:
I'm sure this thread will get buried 2 pages down by some tractor carb controversy, but here we go anyway:
In short, I have been able to determine that the CBR600RR friction plates (not steels) are identical to hawk friction plates. Further, there are quite a number of clever clutch system options for CBR600rr and its relatives, which could provide some attractive performance upgrades to old Hawky.
The strategy is to utilize a CBR600RR clutch center (perhaps a slipper clutch center) with the Hawk outer. Of course, nothing is a bolt on. Specifically, I need to find a way to adapt the smaller splined shaft of the NT650 to the larger spline of the CBR:
There are basically 2 options:
There will be possible other issues, like clutch stack height etc., but I think they are solvable. The main thing is getting the center adapted in an elegant way.
Any advice? Volunteer to help? I am happy to send some parts if you'd like to have a go...
- Machine an adapter with the inner for the hawk and the outer for the CBR (see dims in the pics) - the difficulty is figuring out which exact fit/type the spline is (ANSI, DIN, JIS?) and having one made.
- The Hawk spline is a pressed-in steel insert, I could extract it and machine the CBR plate to take it. This is a very cost effective solution, but I am worried about strength. Plus I have to permanently sacrifice the parts.
