Videos are too big to upload so I made a flickr account to link them. Just got the bike started for first time since ive owned it. I cleaned the carbs after it would only run on 1 cylinder. Clogged slow jet and stuck float valve later it runs on both cylinders. It surges during idle however, i didnt check float height before putting it back together, and i havent touched the pilot screws. Could either of those cause the surging? Slide diaphragms were in pretty good shape. Im mostly concerned with the white smoke coming out the exhaust and around the headers after running for ~30 seconds. Both cylinders do it, does that mean coolant leak? Second video shows it pretty well. Thank you any advice would be appreciated.
First Start
First Start
Videos are too big to upload so I made a flickr account to link them. Just got the bike started for first time since ive owned it. I cleaned the carbs after it would only run on 1 cylinder. Clogged slow jet and stuck float valve later it runs on both cylinders. It surges during idle however, i didnt check float height before putting it back together, and i havent touched the pilot screws. Could either of those cause the surging? Slide diaphragms were in pretty good shape. Im mostly concerned with the white smoke coming out the exhaust and around the headers after running for ~30 seconds. Both cylinders do it, does that mean coolant leak? Second video shows it pretty well. Thank you any advice would be appreciated.You do not have permission to view this gallery.
This gallery has 1 photos.Tags: None
