Still working on bringing my 2nd Hawk back to life. Ignition switch contacts cleaned, Carbs rebuilt, valve clearances adjusted, Nuetral switch replaced, fluids, etc. It now starts & runs but only on the rear cylinder. No spark to front cylinder.
I've been troubleshooting forwards and back and finally took a look at the fuel pump relay. Its been removed & bypassed by a PO. However, it looks to me like its done incorrectly. In my understanding, connect the black & black/blue wires together and that's it. Attached pic shows the blue/yellow wire from the coil also attached to the two aforementioned wires.
I'm going to disconnect it and see if that fixes the issue, but wanted to do a quick sanity check with the pros here first.
Thanks in advance!
Thanks in advance!
