Hi, first post here and first Hawk I've worked on. I think I posted to the wrong section last time, my apologies. Was going to adjust the valve clearances so I pulled the valve covers, everything looks pretty good, bearing surfaces and all, but it seems like the cam chains both front and rear had a bit of play in them. They seemed pretty tight, but I could pull them a touch at the top of the cam gears. I've rebuilt a CB motor before, and this doesn't seem right to me.
Searching around, I found this page http://homepage.eircom.net/~hondabros/CAM_CHAIN.html which was referenced in another post here. What's odd is that while the other poster's "wedges" were flush, mine are ~3mm into the tensioners (both seem to measure the same). The chain tension only changed a slight amount as I was rotating the engine by hand, and exhibited this "play" throughout the whole cycle.
Should get ready to pull the engine to replace the chains? Could the chains be fine and just need to replace the tensioners? The bike runs seemingly fine, it's got ~50k miles.
Many thanks!
Many thanks!
