Well I got the Hawk up and running after adjusting the valves and took it for a spin, and I've got to say these bikes handle amazingly.
After riding it for a bit, I started to notice some weird behavior. It was stuttering/backfiring around the 3k RPM range, but eventually would climb to redline no problem. The carbs were just rebuilt, so I poked around the forums and decided to mess with idle mixture screws (turned from 2.5 out to 2.75). I could tell the bike was immediately way better on idle, and didn't experience this stutter/uneven pulling anymore.
However, as I was riding it and it started to get hot out, it started to lose power, almost like it was misfiring or losing the rear cylinder. As I pulled over on the road, it shut off on me. Gave it a little choke and was able to baby it home, but it had absolutely no power and I'm confident it was running on one cylinder. The idle wasn't right either; without touching the idle mixture screw, it was only idling at 1k.
Pulled the plugs just after making it back, front plug looked alright, but the rear plug was wet with fuel. I'm assuming this has something to do with ignition, as the rear cylinder is obviously getting fuel? The front header was hot, but the rear was only warm to the touch.
Followed the FSM's ignition diagnostic, and other than cleaning connectors, I found no problems:
- Secondary coils: 32.7k ohm (rear)
- Primary coils: 2.3 ohm (rear)
- Primary at 6P: 2.6 ohm (rear)
- Pulse gen at 4P: W/B and B (rear): 453 ohm
Everything seems to check out, I'm stumped with this one. Anything else I should be looking at? Going to run and grab some new spark plugs later, and will update. The bike has an aftermarket exhuast and K&N air filter with the airbox lid removed.
What's weird is that it will seemingly run fine for quite a while, and then start experiencing these problems randomly. If it was a carb issue, wouldn't the bike run like s#!t all the time?
