Since I couldn't find a topic where this specific symptom was discussed, I created a new thread.
Context:
88' Hawk 650.
Bought the bike few months ago with 16k miles on the odo (probably rolled back). Bike ran fine.
Did some way overdue maintenance on it. Fluids, filters, valve clearance and cleaned (ultrasonic) and rebuilt the carbs. Set float height to 9.2mm. Membranes all in good shape.
Problem:
While riding, now and then the bike gets starved of fuel and cuts out.
Diagnosis:
After it stumbles or dies, the fuel filter is empty or only filled up a little (maybe 20%). In my perspective it should be full.
It doesn't care whether you are pinning it, cruising riding on the highway @ 80mph or slow stop and go city traffic.
It comes and goes at random moments.
I did check the fuel pomp as described in the manual. Inspected, sanded and cleaned the points behind the black cap. Pulled fuel line T joint on carbs, pulled relay and connected blk/blu and black. Pump works perfect with ignition on. Reconnected fuel line to T joint and with float bowl drains open checked again. It's happily clicking away like it should.
It also stops by itself after the bowls are full.
The relay's contacts are obviously not welded since it works most of the time.
But it seems to hesitate now and then and doesn't want to power the pump.
I am suspecting the relay here being faulty, what do you guys think?
Thanks Lucas
Context:
88' Hawk 650.
Problem:
Diagnosis:
Thanks Lucas
