removing wheel bearings from RC51 wheel
    Anyone have any advice about going about removing bearings from an RC51 front wheel?
    if your not going to reuse them, use i small diamter tube or steel rod, and tap them out making sure to tap around the periphery of the bearing equally making sure not to knock out one part of the bearing much more than the rest...(you dont want to cock it)...if your saving them......do the same...but make sure you do not hit the seal with the tool....or you will need a new bearing......not too hard...just have to pay attention to where you hit the bearing.......there are bearing extracting tools...but ....they can be a bit pricy
      I'm inserting 954 bearings...
      so yes, I have new ones which will go onto a 954 fork. Thanks for the advice.
