Is there something wrong with the clutchbasket ?
im not sure if the bros clutch fits any other bikes but one place to check is cmsl go onto the schimatic and check the part number then you can check something called linked machines its handy .
One of the 4x threaded parts of the pressure plate has sheared off. I've used the cmsnl site and identified that the pressure plate is the same part number across the nt400 and vt500, but the actual basket is different. Have sourced a complete unit and will cannibalise it for other compatible parts (clutch nut, washer, friction plates etc)
I’m curious to hear how this goes. I am very confident that the basket and pressure plate are the same, but I am not sure if the primary gear (on the back of the clutch) is the same on all models.
I can't say for anything sure but you might check into a honda shadow part if you can not find OEM like parts but you are going to have to measure and test fit stuff at great length. Might need a little custom machining to "make it fit". I'd say best bet is to maybe keep your eyes peeled on ebay for various nt400 and nt650 parts. I see some on ebay right now that seem somewhat affordable. Also other considerations maybe of nt650V.
