Rear Head removal
  • Rear Head removal
    Does anyone know if its possible to remove the rear head without taking the lump out of the frame. Looks like I have low compression on the rear, and its causing me a bit of trouble. Thanks
    Yes, its definitely possible because i have heard (i thiknn even from JD) that JD does 700 installs with the motor in the frame.
    As to how... Dunno, i have never done it.
      As 6 says, it is possible. I found that I could remove both heads and cylinders with the motor in the frame. I can’t remember exactly what I did - may have needed to remove one or more mounting bolts to get the clearance. If you put a jack underneath before doing do so it makes it much easier.
        Great stuff, thank you.
          My understanding from JD is the rear head is easy and the front head is the pain but I have yet to tempt the beyonder.
            Yeah it looks to be a simple enough job, with plenty of space. I just did the leak down test last week and it’s pointing to intake valves so I am hoping the issue is just contained to the head. Compression test shows 25 psi on the rear, and hence she is spluttering. Just as I though I was done with this bike.
              Mmmhmmm.
              ​​​​​​They like to do that.
                Both heads/cylinders can be done in the frame. Rear is easy, front you have to hold your tongue just right to remove the cam tunnel bolts.
                Trivia- I used to install new rod bearings in the race Ducatis I maintained without removing the engine from the frame. You can also do it on SV650's.
