Are these motors just generally a noisy top end? I've only had a few old nut and bolt valve adjustment bikes before, most my bikes have been fairly new. But none of them were as loud as this.
I just got around to doing the valve adjustment on Monday because the tapping has been doing my head in. Found a few well outside spec, but after reassembly the noise was still just as loud. I thought I'd done something wrong so stripped it down and checked them all again, all within spec. 0.14mm on the intake and 0.18mm on the exhaust. Started it up and still loud as hell. I thought maybe I was not getting an accurate read or something was slipping as I tightened it, because I was trying to awkwardly hold a spanner and screwdriver and get around the frame while holding the clearance gauge. So I went and bought a proper motorcycle valve adjustment toolkit and did them all again yesterday for the 3rd time now this week. Still sounds like there's a little guy with a hammer inside my engine hitting things. I'm willing to pull the heads and rebuild them with all new valve gear of that's going to shut it up, but don't want to spend all that money to put it back together and have no difference
