it's still possible to buy replacement jets, but this thread will explore the idea of making our own. eventually i want to be able to make any replacement part for any petrol driven engine, so let's look at some engineering ideas here.
talon kindly provided an image of a slow jet. here i'm using it as an example of trying to find the total surface area of jet bores in a jet, using high resolution photos. we may even be able to calculate the resolution required in order to accurately calculate the areas with necessary precision. of course, if there is a datasheet out there then we could use that instead..
the photo needs to be calibrated first. we take 'A' as the measurement of the actual jet, using a micrometre, to the greatest precision available. then we measure 'B' of each bore in the photo. by using 'A' we can find the area of 'B' without measuring it directly, only from the photo.
exercise : would anyone care to draw up a formula for that, i.e. B as a function of A ?
next episode : how do we reproduce a jet using only commonly available tools ?
( any ideas, feedback or constructive criticism are welcome ! )
