I wonder if the fuel pump relay is actually mandatory?
I believe mine doesn't work and it is very hard to find a new one where I live.
I've noticed that once the relay shorted, the pump will work until the carbs are full, then it stops naturally by itself after it senses enough back pressure.
So basically it doesn't need a relay to get on and off automagically, it does that just by itself.
So I wonder, what is the actual purpose of this relay and can I just run the bike without it?
