Help fitting Fabian bellypan
    got some parts from Fabian in Germany,having trouble with bellypan ,if anyone has bought one and fitted it can you show me where the brackets go ,I know I will have to line them up and then drill holes in bellypan to align everything,but my little brain can't figure out where brackets go on engine casings .
    If I were to guess......there one "front "center" mount and 2 side brackets.If the holes in the pan are pre-drilled.....you have a map.Even if they aren't.....plenty of bread crumbs.
    Match bolts to existing holes.......
      Bellypan isn't pre drilled,still trying to figure it out had bellypans on other bikes ,so have idea of where they go ,just not getting any to line up ,doing something wrong just can't figure out what yet
        Here are some pictures of it fitted - don't know more about it:
        https://www.hawkgtforum.com/forum/ho...llo-to-you-all
          From Jan's post it looks like the side brackets go front...the center bracket somewhere under the rear.
            Check the reach to the threaded bosses on the crossmember.
              Thanks JAN M,pics deffo helped still not lining up as I would like ,have two brackets roughly right third one still struggling with,will keep at it .
                His stuff usualy has a "good enough" type fit. You may be driving yourself nuts going for perfect.
                  Or make your own brackets......
                    make temp brackets from bendy metal - like aluminum soffit or cut up an old gutter. get things set up the way you like, then you have a template to bend the stuff from the kit to your exacting specifications. You don't ride around with the bendy bits, but you can then see the difference between what you have and what you want. a good vise and a hammer (or a rock) will force the kit to succumb to your will.
                    This is perhaps where the term "kit bashing" came from.
                      that is what we did... but we didnt use his..
                      And it was crash proof.. .
                        Bike looks all go.
