I've had two Hawks over the years, and they both had a throttle hesitation when at constant speed, and at ~ 4,000 rpm. Hesitation (feels like bike is running out of fuel) would be made worse by headwinds or passing a semi. Recently I've noticed the issue can be improved by using the choke when at speed. Therefore I believe the engine is running too lean.
I'm not experienced with motorcycle carbs, only have small engine experience from my go-karting days.
I came across this nice web page for "Carburetor Tuning Guide" http://www.nightrider.com/bt30/carb_jet_ranges.htm For someone line myself, this is great to understand at what throttle openings what variables are at play.
I am going to replace the diaphragms with JBM Industries (Part # K-72-S), and while in there, raise the needle a little to see if it helps the hesitation at midrange. I may also try to back out the Pilot Screw by 1/2 turn.
Plan to update if I get some results and will share pic's.
