I purchased a roller bearing kit from made in Japan. I took the top roller set and place the seal on it in my hand. There is free movement of the roller bearing with the top roller set (no grease). So I assumed the bottom set would be ok
On installation for the lower stem, the dust seal was placed 1st, then the bearing was pressed in.
Once this was done, the cage for the rollers would not move. On first blush the inner seal diameter looks too tight and is binding the roller cage.
Thinking, the inner seal area folded when the bearing was pressed, I took a flat brass probe and made sure the inner seal sat outside the bearing.
This did not resolve the issue. So I removed the seal and bearing.
I looked at an All Balls package and placed the seal on the bearing. There appeared to be no binding, but the cage did not move as freely as I hoped.
The question is from users of the roller cage upgrade is: How freely did the roller cage move once you installed it ?
What is your experience? Please, experience posts requested20220429_092401.jpg image_53800.jpg
thanks
thanks
