Can I just impact driver the bolt out and slide the axle out to remove the wheel to paint the front fender.
Front wheel removal for painting only
that bolt should have been tightened to book specs, about 22 ft-lbs, and no impact device should be needed or used."It's only getting worse."
I kind of like tying a small rope from grips to rear foot peg holes on each side. Offers up some stability keeping the forks straight when working on the front end. Depending on of course how you plan to support the front to keep it up once axle is removed. I often remove the caliper and fender on new to me bikes so I can use paint remover on the lowers then polish them by hand. Since the wheel is off it does make that task easier should the lowers clear coat be toast. I don't own an impact driver except for the one 55 years old that I hit with a hammer.Bill,
88 Blue Hawk (bike #39), 89 Red Hawk, 2021 Rebel 1100 (bike 41) Some Past/sold in reverse order:,FZ09,97 Magna #1&2 , 97 VFR750F, 87 VFR400R, 88 Hawk, 86 SRX 600, 77 RD400, 79 CB650, 04 VFR, 88 Blue Hawk, 89 Red Hawk, Yamaha SRX600, Harley 1200C, Yamaha RD400, Harley 883R, Yamaha 750 triple, Vlx600, Honda 450, Honda 400, CB550F, Kawasaki H1, BMW R69US, Yamaha R5C 350, Honda 160, Bridgestone 175, 1950 Harley 74 w/sidecar, 65 Harley 250 Sprint, 1948 Harley and my 1st bike-1941 Harley 74 knucklehead my dad gave in1963.
Download the Factory Service Manual.
Don't try anything without consulting the FSM.
Originally Posted by racerboy4 View PostOk thank you all for the inputs. Talon, left pinch bolts standing at front of bike or on it? Ok no impact just socket and breaker bar. I really appreciate all the comments guys. Does anyone know if Jas88 is still doing decals for the hawks?ASMA #139
And don't use a hammer to push the axle out. Compressing anything threaded will "adjust" the thread pitch. If you have to start the movement by tapping it out, leave the bolt in it. Loosen it only a couple threads then tap on it until the bold flange is seated again. Spray lube and pull it out using the holes in the other end.
Originally Posted by ParcNHawk View PostDownload the Factory Service Manual.
Don't try anything without consulting the FSM."It's only getting worse."
Originally Posted by racerboy4 View PostOk awesome will do. Where can I download the FSM?ASMA #139
Originally Posted by Maritime View Post
I just scratched mine LOL. I will have to do this the next time I paint it.
Even still to the day after scratching everyone I've installed with the forks in place I feel if I try hard enough........
But it never works.Don't spend money and buy, spend time and learn.
