Exploed view of Key assembley wanted - No running lights
  • Exploed view of Key assembley wanted - No running lights
    Hello
    Currently I have no running lights front or back
    Engine starts and all the other lights/accessories/ gauges work .And I have checked all the connecting points everywhere including the fuses
    I would like to see a view of the internal key assembly before tearing things apart .Does any one have photos of the key assembly as I suspect there is a fault within the key mechanism.
    No I am not going to do volt/ resistance tests.
    If there is a continuity test for running lights, I would like to know that
    H2
    No rear running lights meaning no tail light? Or no dim glow from the rear turn signals?
    For the front: there is a brown wire with a blue stripe that connects to a brown wire with a black stripe via a bullet connector you should check. It resides in the headlight housing.
      Or you don't have stock front turn signals and they don't have a running light function at all.
        Tail light does not illuminate- The brake light works
        BTW which wire from the ignition switch runs the tail light?
        The headlight issue was found with a faulty wire.
        Kinda strange both headlight and running tail light went out the same time- but stuff happens
        H2
          It doesn't directly. The ignition disconnects all the other lights so the tail light can be left on with the key in the P position. The tail lights are always part of the circuit.
          The schematics of all the switches are at the bottom of the wiring diagram.
