How to Deal with a Baked-on Gasket ?
I bought a clutch kit from Hord Power and am in the process of installing it.
In replacing the clutch on my 1988 Honda NT650, I found that the clutch case gasket had baked onto the engine. With a lot of work, I was able to scrape off the 1% of the gasket that had adhered to the cover but the 99% of the gasket that is on the engine is hard-baked and impossible to me to scrape off without doing a lot of damage to the aluminum engine surface.
I would like help on what to do next. I think there are 3 choices ... non of the good.
A. Scrape the gasket off: Are there best products to use to soften the gasket and scrapers ?
I do fear messing up the aluminum surface.
B. Use the old gasket as it is in place and use a gasket compound: Good gasket compounds ?
What about the missing parts of the old gasket ?
C. Install a new gasket over the old gasket and use a gasket compound between them. Any good choices for the gasket compound ?
I thank you for your expertise. I am at a loss and at a standstill until I fix this problem.
