Scratch rebuild of my Japanese import Bros 650 Mk1
  • Scratch rebuild of my Japanese import Bros 650 Mk1
    Hi all
    I am getting started on my Honda Bros 650 over the winter months in the UK and will post pics and progress, hopefully to get done by August 2023.
    Just a quick question, I'm fitting a VFR750 rear wheel, can anyone confirm if it will take a VFR750 180 section tyre without fouling the Bros swing arm. I have the VFR Hub and that fitted well.
    Regards. Hubert
    I don't know the direct answer, but I have a question that may end up being relevant...
    What year VFR wheel? or... 5.0" or 5.5" ?
      I am running a five-spoke VFR wheel with a 170 section rear. It just fits, and actually is more tire than I need. I believe that a 180 tire may require you to sand the inside of the swing arm, but I'm sure others here know.
        Thanks both, I have new tyres which were bought to fit the Bros wheels, does anyone know if the handling would be affected adversely if I fitted those.....its a 97 vfr 5spoke wheel and i'm using a cbr600f3 front.
        Thanks in advance
          I don't think a 180/55 on a 5.0 rim is recommended. But a lot of people run tires beyond manufacturer's recommendations. It will change the profile it was designed to have. 160 or 170 is the sweet spot on a 5".
          I have 5.5" rims on two VF1000 and I still run a 170/60 because I prefer the profile.
          What size tires do you have for the BROS wheels?
            Hi sorry for the delay in replying, I have a 110 70 17 front and a 160 60 17 for the rear...I also have a matched new front in 120 70 17 if needed.
            Thanks in advance
            Hubert
              The 160 rear for the 5.0 rear is just fine, as the CBR600F3 with a 5.0 came with that.
              The front I am hesitant to comment on. Pretty sure that is the size (110/70) I recently got for my CB-1 with a 3.0" rim.
              But, the few tire size / rim width charts I just visited list a 3.5 as acceptable. And if given an acceptable range, I prefer to be on the wider end of the rim spectrum for a particular tire size if the nominal recommended combo is not an option.
              I'd personally go for it if I had already purchased tires in those sizes. But somebody will now come along and say you're gonna go straight into a ditch and die. Its just the way these topics seem to go.
              Edit: I see you updated your post to say you also have a 120/70. Run that. Sell the 110 to somebody with a stock bike.
                Thanks , that's very helpful...it's good to know that I can use existing tyres which I have already.
                I'll post up a picture soon of how it stands at the moment.
                Cheers H
                  I've just discovered the bottom frame slider is nla, has anyone got a solution for this? Maybe from another Honda model or make one from a rubber block
                  Thanks in advance
                    frinesi2 makes chain rollers
                      Thanks I've sent a private message to him
                        Thanks in advance
                        The temporary solution I used was to take some regular corrugated cardboard, wrap it in duct tape to protect it, then tape it on the frame so that the chain runs on it.
                        I made about 300km so far with this and it worked just fine, not even a scratch on the tape, I was surprised.
                        Obviously not a durable solution, but if you need it to work for a while it is a good trick.
                        If you can wait for a few weeks and are not in a hurry, I am working on a 3D printable slider, I'm fairly confident it is going to work.
                          Thanks however I'm going to make my own bracket and fit a good quality chain roller.
                            If you can do without the center stand and side stand you can get rid of that whole interference with a sawz-all..
                            Just an option.
                              This, chain roller. Then you can run your chain loose and never worry. Plus, I need my center stand.
