Rev counter rubber ring
    Im looking for the rubber ring that goes round the rev counter for honda bros its coming up as part no longer available ? .
    im just wondering does anything from another model fit ?
    i used some rubber hose .........
      Check the plumbing isle for a flat rubber gasket and see if you can cut to fit. Or check other Honda models for a simular piece ... f2 f3 f4 maybe ?
        I'd just get some 1/4 inch vacuum hose and split it down the middle, then trim it to fit around and make your own. If you want to seal the cut on the ends to make it one piece you can get it fitting and then put a dot of superglue on the joint. Chances are you will find a whole replacement set of gauges before you find just the rubber piece, unless someone has an accident and you can find the gasket in good shape..
        88 Blue Hawk GT - Under construction
        89 Red Hawk GT - Still on the shelf and in crates
        2000 DR650 (Thumper)
        2002 DL1000 V-Strom
          I知 pretty sure I have a spare set that I値l never use. (No clocks). I値l have a look next time I知 back home. If you haven稚 sourced one I値l get them to you. They are used but still in good shape iirc. Been a while
          90 Bros 650... Under Construction
            Thanks but ive already ordered the two speedometer rings im gonna try and shorten it for the rev counter but if it dosent work ill buy it off you
